hadukla wrote:
THRILLHO wrote:
Sbernardi wrote:
And I still think that, for the most part, anyone who BQ at an IM should get inI agree, but then all the run courses would have to be certified. From what I hear, Kona is the only one that is certified (but even then, you still have to get within the cutoff at Kona).
I think a lot of people here on ST would love for all IMs run courses to be certified, not for BQ purposes but for the need of accuracy!
Just to play devils advocate. People here will know better than me but to get a marathon accurate presumably you measure the bulk of the course then move the start/finish a bit to get it right. The exact distance will be the blue line route and, I guess, you choose barriers and such like so that there are no corners to casually cut. With most marathons, again I'm guessing, you are more likely to want the finish somewhere very specific so the give and take bit is more likely to be at the start?
With a Triathlon don't you have less room to play with the start of the run because of T2? If so maybe you could say any extra run is still transition and then the accurate marathon begins at a designated matt/line. But then aren't you just getting a longer run with an arbitrary line rather than a more accurate run? Would most people be happier with that? People who miss cut offs/pbs because of the extra run. Maybe you just have a 180 turn somewhere up and back a side road to get the distance right? Also maybe there are other parameters like drop and surface that would be required that would take some of the flexibility out of the run route? Just thinking out loud if it would be as simple as we're making it out to be.
Am I making sense? TLDR It seems it would be hard to get T2 and the desired finish line to be exactly marathon distance since the fixed nature of both doesn't gibe you much to play with.
