looberforce wrote:
Hey
This is really interesting, but i dont understand how you implement it to
improve your everyday training, and also finding which atl/ctl number is optimum for maintaining performance while avoiding injury... I understand its different for everyone, so how do you find the number that is right for you..? Is it just trial and error or am i missing something
This approach will NOT inherently improve your everyday training. I say that because there is no NEW information in the ratio of ATL:CTL that isn't already in TSB. As described above TSB and ATL/CTL are equally sensitive to daily TSS. When one moves the other moves in the opposite direction and by the same proportion (not magnitude, but proportion).
So, everything that you know (or don't know) about how to find your "ideal" TSB applies to finding your ideal ATL/CTL and vice-versa. Also, both approaches must be scaled to your current weekly CTL. So, your ideal (or maximum) TSB or ATL/CTL ratio will be different when your CTL is 20 vs.100.
Yes, its a trial and error process. But, since every single day is a trial and an opportunity for error. If you pay attention to it, and how you feel every day, and how you perform on "key" workouts. It doesn't take long to determine what works and what doesn't. The key there is probably to start somewhere REASONABLE, and then scale up or down based on how you feel (too easy, or too hard). Also know that it takes about 3+ weeks for things to really settle in.
Also as I noted above, the ATL/CTL ratio approach is exactly analogous to planning by scaling factors of CTL. If every day is planned as a scale of CTL (eg, 1.4 * CTL), and adjusted weekly to the ever climbing CTL, and that week scaling is repeated 3-6 times in a row the ATL/CTL values will stabilize to a fixed set. I gave one example above, which stabilizes to a set of values similar to what Miles suggests.
This CTL scaled approach (or the equivalent ATL/CTL approach, since they are equivalent) works best for me in the mid-range of my training...when my CTL value spans from about 40-80. Below a CTL of 40 it leaves me undertrained....applying the same scaled week above a CTL of 80, I would quickly end up over-trained. That is not to say that you couldn't have a different set of scaling factors for CTL<40, 40<CTL<80, and CTL>80. You just need to determine what those are. Again, its not hard...one week will quickly tell you that you've (under)overdone it, and you can scale (up)down the next week.
