Ironma'am wrote:
Where is the best place to look up the wind forecast? I’m trying to decide between two front wheel options, an enve 4 vs a hed 6. I’m small and on 650 wheels.Not quite the same, but my wife rides a Zipp 404/808 combo on her P3. I ride dual 404's.
For wind forecasts .. good luck. Try finding Guy Hagi's forecast on Facebook or Hawaii News Now. He usually gives race day forecasts.
Or Accuweather.
Honestly, it's going to be calm in town. Winds will start picking up from cemetery northwards. Out in the resort areas you'll have a headwind with a cross wind component on it all the way to Kawaihae junction, although the winds should vanish around the Mauna Kea Hotel for a bit. Descending to Kawaihae from the junction you'll have a headwind or no wind. Making the right turn onto the highway to Mahukona and the Hawi climb will be strong crosswinds. These can be troublesome. As you pass into a grading cut the wind vanishes then when you exit the far side the wind will actually be from the opposite direction for a moment then switch to the direction it had been coming from.
The climb to Hawi is usually a headwind. On descent for the return you usually have a tailwind, but not always (2009 had everyone peddling down that hill). Winds are usually on the opposite side for the return to Kawaihae (unless a serious wind shift has occurred). Climbing to Kawaihae Junction is usually, but not always, calm. Make the right turn onto the Queen K and ..... unless you're up with the pros the winds will have shifted direction and you'll have a headwind all the way back to town (or the airport anyway).
The crosswind gusts on Akoni Pule Highway (Kawaihae to Hawi) are the reason disc wheels aren't allowed. The crosswinds and gusts can be as strong out by the resorts and all the way through the airport as well. Odds are extremely high you're going to have headwinds both directions.
The difference between stupidity and genius is that genius has its limits. -- A fake Albert Einstein "quote"
KonaCoffee: Oct 9, 18 11:28
