That's a good question - I had a lot of little issues with Latex tubes that lead me to this point.
I will start off by saying that the data/research out there is unquestionable and my personal feel with latex also indicates that they are superior and "easy" or "free" upgrades to achieving less rolling resistance/speed.
Here was my issues or struggle with them;
1. Ruined 2 tubes upon initial instillation - When I decided to try and convert tubes for the race season during January of 2017 I was not aware of how fragile the tubes were. I ordered 2 tubes and while installing them I ripped one with a tire lever (The Enves are very hard to install tires on) and the other one I cannot remember what happened but I did something silly. I took to the forums and online and learned about how fragile they were and how to better install them (powder them, air them up, push them up into the tire, verify not inbetween bead etc).
2. Latex tube found its way into a spoke nipple hole - I Finally got 2 tubes installed with no issues, I repeated the process a few times to verify I was doing it correct. I at this point had purchased 4 latex tubes - I went and did my first race and they performed great! I was sitting after the race at a campground relaxing and heard my front tire pop....... When I got home and inspected the latex tube had worked its way under the plastic rim strip (was slightly pinched there) and into the spoke nipple hole eventually popping.
3. Latex tube gets under tire bead - This is the one that finally did it for me, I am now 5 Latex tubes into this project or test and I approach a 70.3. I fixed the tire/tube combos a few months prior after the spoke nipple popping it and let the wheels hang/sit in my garage. I did not test the tubes/tires before getting to the race and the day before during my bike practice I aired them up like normal and went on to race. When I get to T1 my tire bead is blown off and the tube is torn in a very long length. I ended up with 2 flats that day and beyond frustrated. I believe the issue was that while sitting in my garage the bead unhooked off the rim and when I just willingly pumped it up the tube got caught between the bead and rim...... The other factor could be that the Enve rims have some Burrs on the beads that are fairly aggressive, maybe that was the issue.
I am now here a month and some days after my 70.3 and have just elected to go back to Butyl for the time being, why does Enve not recommend the tubes? I believe it is something to do with the brake heat - maybe its the rim imperfections will cut them more easily but I am not certain outside I know they just don't recommend it.
With that being said I had seen my latex tubes survive a puncture and not pop and as stated before they felt amazing. If you care to read here are the threads I had on it;
https://forum.slowtwitch.com/...w_P6649476/#p6649476 https://forum.slowtwitch.com/...n_P6691732/#p6691732
