I think most of you are pretty spot on. The only thing I will add is that Bike Special Needs bags are not necessarily available on the second lap. Because of the way the course is laid out, its possible, but I wouldn't plan on it, especially if youre later in the day. Once that cutoff at the first lap is over, we tear that area down. As some posts have mentioned, once you exit the swim, dismount your bike, etc. we've got you... You cant screw it up! You are physically barricaded in and forced to go through the correct chutes. Hundreds of volunteers will be in transition to help guide you as well (thank them).
No major changes this year, same swim, bike, and run we've used for a few years now. Im sticking with the first come/first serve swim start line. With the 16:30 finish cutoff, the folks who are worried about missing the physical cutoffs will always go at the front, therefore screwing up the process. Once you get a few hundred 2ish hour swimmers at the front, the self seeded stuff is a wash. I wish it wasnt that way...
Water temps have been similar to what we have seen in previous years, wetsuit legality will come down to race day as always with this one. With rain, it could be close, without it, Id expect it to be a degree or two over. If its wetsuit optional, we will once again ask wetsuit wearers to step to the side and form a second line that will start after the non wetsuit wearers.
See you in a few weeks.
Brian
Brian
