I just got a 2012 Cervelo P3 and I am considering buying a used set of Hed jet 6 plus. Can anyone tell me whether the wheelset will fit? Or are the rims to wide?
Re: Hed jet 6 plus on 2012 Cervelo P3 [Karstenks]
2012 P3C?
If so the rims fit just: front ok, rear very close.
Tyre choice will be limited: I had to run 23 GP4000 as the 25 rubbed on the rear.
I was running Hed Ardennes plus (same rim).
I ran he’d jet blacks on a 2012 P3....no issues at all with the rims. The issue is that too many people try to use 25mm clincher tires...which are like 27/28 once aired up...get some 23mm Vittoria’s...and you will be fine.
Re: Hed jet 6 plus on 2012 Cervelo P3 [zooropa]
Thanks.
How durable are these wheels? Seller says there are som wear on the aluminum brake pattern, and otherwise fine. Could the aluminum part wear out?
Yes.
