Sharing wheels between bikes
I'm in the process of building a new Tri bike and the wheels are going to end up being my budget breaker. I have a set of Hed Jet 4+ on my other ceepo and thinking I would just switch them back and forth depending on which bike I'm riding.
Anyone else do that?
Is it a pain in the butt?
Re: Sharing wheels between bikes [Etip] [ In reply to ]
I have a FLO 60/90 front with a FLO 90 rear which currently I'm sharing between my roadie & TT bike... normally leave the TT on my direct drive trainer in any case I feel froggy & wanna ride the TT... painful yes but worth it at the moment
Speed kills unless you have speed skills!!!
I have 3 bikes and 6 sets of wheels that I'm routinely swapping around from bike to bike for various reasons. All 3 bikes have 11-speed and all wheels have cassettes and tires installed so swapping them from one bike to another just takes a couple of minutes. If I had to swap tires and cassettes it would be a bit more of a hassle but still not a major issue.
Why not just get a set of cheap training wheels to train on? Seems easier than constantly swapping wheels (assuming you switch between bikes fairly often).
Strava
Re: Sharing wheels between bikes [gmh39] [ In reply to ]
How long does it take to remove wheels from one bike and put them on another? 60 seconds?
Re: Sharing wheels between bikes [BrianB] [ In reply to ]
Sure it doesn't take long, but if you're switching between bikes a couple of times per week gets annoying.
Strava
What is annoying is if you have race tires / tubes. Then swapping wheels is a chore because you probably don’t want to ride on your good rubber during a training ride. So a wheel swap is a wheel, tire and inner tube swap.
The n+1 rule is probably more appropriate for wheels than bikes. I always wish I had another set of wheels. I guess that makes it the 2n+2 rule for wheels.
Re: Sharing wheels between bikes [grumpier.mike] [ In reply to ]
While I completely agree with this... n-$1,000 is the barrier.
Thanks for the replies.
I'm good with keeping the one wheelset between the two bikes for the initial build/time being. Sounds like it's not that uncommon.
I can go for a different or at least deeper rear as funds allow next season.
I used to do it, huge pain in the ass.
It worked til I could afford a nicer set for the TT bike though!
Bonus points, without the rush, you can wait for the right deal!!
I scored a HED Jet Disc with a powertap hub in it a while back for $800 canadian.
I MADE that one work :p
Re: Sharing wheels between bikes [dfquigley] [ In reply to ]
Exactly
$1,000 for a set of training wheels isn’t required. I think the more appropriate question is this: which is more valuable to you. Having cool wheels to train on (and swap back and forth) or having a set for each bike (cheaper wheels). I bought a new set of HED Ardennes wheels from My Bike Shop for like $700 and they’re awesome training wheels. Look good, roll smooth, super high quality.
Re: Sharing wheels between bikes [triguy86] [ In reply to ]
On my current Tri bikes I train and race on the same wheels. I think it's important to know the feel, etc. when wind catches your wheel and you're in aero position.
My plan is sometime in the next year to get a deep rear wheel and continue to swap the Jet 4 back and forth.
In the meantime I will swap both wheels.
Well Flo 30s are 500$ and they are pretty nice wheels that fit somewhere between great training and low-end race wheels. I train on mine and use them for racing on gravel.
I've never done the training wheel / racing wheel separation.
Just train and race on the same wheels, no surprises race day with handling or minor brake adjustments, bike looks more badass too.
