These are 2018 Zipp 303 NSW Carbon Clinchers, Shimano/Sram, 10/11 speed - You can run them with tubes or tubeless. These were brand new wheels from a new build for a customer who decided to go with a lower profile training wheel for day to day action. They have not been outside. The kit comes with the skewers, pads, and very nice padded wheelbags. These are incredibly light, very stiff and some of the best wheels out there.
The retail on the front wheel is $1400 MSRP (see below at the very bottom)
The retail on the rear wheel is $1800 MSRP (see below at the very bottom).
Price: $2300 and free shipping in the usa.
PHOTOS: https://flic.kr/s/aHsmoDBiQW
The are currently boxed and will ship from the shop the same day or day after monies are received.
Any questions, please ask.
Ride away. Explore boundaries. Do so with speed, stability, and control. That’s the 303 NSW Carbon Clincher Tubeless Discwheelset. Zipp’s 45mm rim depth proved ideal as a do-it-all wheels for cobbles, pavement, cyclocross, and gravel. Now add to that tubeless compatibility and options to run wider tires.
Considering Road Tubeless? Start Here
Without the constraints of rim brake caliper compatibility or brake-track requirements, our engineers were free to modify the NSW rim design to be disc-brake specific as well as to be more aerodynamically efficient and stable at the most common wind angles. For starters, the ABLC™ Sawtooth™ dimple design extends all the way to the rim’s edge. The result is greater AeroBalance™, our name for optimized aerodynamic efficiency and crosswind stability.
The 303 NSW Tubeless Disc-brake is optimized for wide tires to meet the performance needs of modern riders in search of low rolling resistance and high comfort. Additionally, our engineers carefully considered the rim-to-tire interface and how specific tire and rim widths affect aerodynamic performance. With an internal width of 21mm, the wheelset test fastest with a 28mm tire in the majority of wind angles.
Designed to be tubeless compatible, the 303 NSW Tubeless Disc brake wheels feature a rim bed made with internal ridges to lock the tire’s bead in place. A tubeless setup allows you to run lower tire pressure for more comfort while reducing the risk of pinch flats.
COGNITION DISC HUBSET
Every time a conventional hubset starts to coast, friction within the freehub ratchet mechanism works like a drum brake to slow the rider down. With the Cognition Disc-brake hubset’s Axial Clutch technology, we’ve reduced this drag by disengaging the ratchet mechanism when coasting. Our testing shows that the best traditional three-pawl hub designs have twice the rotating friction as our Axial Clutch equipped Cognition rear hub, and the most popular hubsets using a similar drive mechanism as Axial Clutch were found to produce four times the rotating friction.
All NSW rims are handmade in Indianapolis, where Zipp's engineering, manufacturing, and testing are conducted and includes "The Nest" advanced development lab where NSW was born.
Each Wheel Includes:
Front wheel: $1,400 / €1,300
Rear wheel: $1,800 / €1,700
- Zipp Tangente Quick Release Skewer
- Zipp individual wheel bag
- Zipp Tubeless valve – factory installed
- Tubeless rim tape – factory installed
- Valve core removal tool
- Zipp Cognition thru-axle caps to fit 12x100, 15x100 and 12x142 dropouts
- Freehub body spacer – 11 to 10 speed
