Anyone know if you can run a 33mm tire on a 2017 Specialized Roubaix? I currently use 28mm Gatorskins. Thanks in advance
Re: 2017 Specialized Roubaix max tire size? [skarkokc]
I believe it's rated for 32mm max. You can likely squeeze in a touch more.
Re: 2017 Specialized Roubaix max tire size? [GreenPlease]
Yes, 32 but you should be able to squeeze a 33 in there without a problem unless perhaps you are using a very wide rim.
Great, I appreciate the input!
