I rent a cottage every year - never any issues with water supply. It is the usual: hose from the lake, water pump, pressure tank setup.
This year the owner just had an inline Rainfresh sediment filter installed. Ever since, the water supply will just shut off while in use - usually for longer duration like a shower or dishwasher or washing machine. The pump won't lose prime, so five to ten to fifteen minutes later the water will come back on normally.
I have the filter on the bypass setting and it still doesn't matter - same result. If I switch the filter setting from bypass to on, or from on to bypass, it seems to release pressure in the system and the pump will kick in immediately and the water will flow fine.
If I had to guess, I would think the filter is creating some kind of vacuum that is tricking the pressure tank/pump into not realizing that water needs to be drawn, but I can't figure out a solution.
Any tips appreciated.
