https://www.homedepot.com/p/Square-D-QO-100-125-Amp-Load-Center-Outdoor-Generator-Interlock-Kit-QOCRBGK1/203078522
Power at my upsate house has become less reliable; more storms, bigger areas without power, longer waits to get back on. I'm getting a 10,000 watt Generac generator and I was looking at Generac transfer switches but they come pre-wired with 15 amp breakers and they're prewired. I'd have to junk all that and use a 30 amp and 20 amp two pole breakers for my water heater and well and 20 amp single pole breakers for my gp circuits. So there's a lot of waste.
Started thinking; what about if I used my own sub-panel, what would I need for a switch? I found a Square D lock out for the sub-panel. Then I found this generator interlock that mounts right on your breaker panel. It's all you need, along with and inlet box to plug into. With a 10,000 watt generator I can probably turn on my whole house, except for the electric range
I called my electrical inspector but haven't heard back from him and probably won't til next week. I found online that some areas don't allow this because you could take it off and turn on both you input breaker and the main and then energies the lines outside.
So, has anyone had experience with this? I'm ready to go ahead with it as soon as I can get approval from my inspector.
''Sweeney - you can both crush your AG *and* cruise in dead last!! 😂 '' Murphy's Law
