ret123 wrote:
No I haven't bought wheels yet, just the stock Bontrager ones it came with. That was going to be another thread :)
Ideal tire will vary a bit depending on the wheels. Generally it's best to use the biggest one you can fit on the rear (up to a 25mm) and a smaller one on the front... unless your wheel is specifically optimized for a 25mm.
What events? You mentioned UCI so are you doing TTs?
They don't get talked about much, but the Michelin Pro Competition is one of the fast but not crazy fragile tires. In the same realm as the GPTT and Attack but with a little thicker tread. The 23s at least run smaller than the Conti 23s. Don't know about the 25s. The Continental Supersonics should be Conti's fastest tires, and the 20mm is still great, but for some reason the 23 is no better and maybe slightly worse than the GPTT.
Tufos are extremely slow tires. With new equipment you may very well end up faster than ever on less power.
