burnthesheep wrote:
You said you get it so the big ring won't grind but that it won't shift into the big ring, right? That sounds like it is too far left, towards the small ring. This means that you're likely setting it up to not rub the FD cage in the slower cogs while in the big ring.
Does the Di2 also have the "in between" trim like with a normal shifter? Where you can give it a half click and get it closer?
Di2 auto-trims depending on what gear you are in on the cassette. No "half click" anymore (just 2 modes for small and big chainring). But setting it up is the same as a mechanical to have enough clearance for big-small and small-big combos for the limit screws.
