Do conti GP4Kiis 23 mm tires not fit? Also are the horizontal dropouts not supposed to have centering screws? I'm having trouble keeping the FLO disc (2016) straight and tire from rubbing the chain stays.
Re: Former Parlee TT 2011 owners [Yeti racer]
Mine does not have screws on the dropouts. You could use a dropout chain tensioner if needed. As for tires, I have 23mm Michelin power competition on jet 6+ that measure 27mm wide... They fit but tighter than I'd recommend. Something measuring 25mm should be OK.
Re: Former Parlee TT 2011 owners [CyclingClyde]
CyclingClyde wrote:
Mine does not have screws on the dropouts. You could use a dropout chain tensioner if needed. As for tires, I have 23mm Michelin power competition on jet 6+ that measure 27mm wide... They fit but tighter than I'd recommend. Something measuring 25mm should be OK.So when you install the wheel into the dropouts, should it be all the way in? I have to back out the wheel just a bit to keep it from contacting the chainstays.
I am able to slide my wheel all the way forward but it will definitely depend on the tire/rim combo and what tire profile results.
