BLeP wrote:
axlsix3 wrote:
Phill Mickellson cheated and should have been dq'ed.
He didnt cheat. He made a decision to have this rule work in his favour.
Was it sportsmanlike? That’s debatable. But it definitely wasn’t cheating.
He knew exactly what his penalty would be and decided that he’d rather take the penalty than play from off the green.
Don’t like the rule?Lobby to change it.
Do you honestly buy that explanation? Maybe. I’ve never seen any other pro ever do anything like that.
If this was strategic, like fouling late in a basketball game, it seems like this wouldn’t be the first time we’ve seen it. I think his head wasn’t in a good place and he was frustrated and he just did it without thinking. That said, The rules issue is that the USGA basically decided to give Phil the most generous ruling they could. They ruled under 14-5 which says a player may not take a stroke at his ball while it’s moving. However, they could easily have ruled under 1-2 which says a player may not attempt to exert influence over the movement of a ball in play that rule has a clause allowing for DQ if it’s a serious breach.
I’m not sure I’d call what Phil did a “stroke,” or an attempt to influence movement. He didn’t really line up, aim, etc. he just tapped the ball to “influence its movement” to keep it from running off the green.
Slowguy
(insert pithy phrase here...)
