So, I am a Power Meter noob and am thoroughly confused about a few things regarding calibration. So, I have a Garmin Edge 500 that is paired to the power meter. I also ride Zwift and have the same power meter paired to Zwift. Since Zwift doesn't give me a calibration option can I calibrate on the Edge 500 and have that calibration be valid on Zwift? Meaning does the calibration on the Edge actually save a calibration value on the power meter itself that then results in a valid calibration for Zwift? Or is the calibration value something that is only valid on the head unit that I used to calibrate the power meter with?
If my calibration is only valid for whatever head unit I use to calibrate with then how do you calibrate a power meter for use with Zwift?
Hopefully that is clear. Appreciate your responses to bring me up to speed on this stuff.
http://dontletitdefeatyou.blogspot.com
