MTBSully wrote:
What are your thoughts on Schwalbe tires? I like their MTB tires, but have had some rather porous tires that took a ton of sealant to hold air.My only experience is the Schwalbe Pro One, which is the racier end of their line. They're easy to install and to get the initial seal. They hold pressure great, and I've had no problem sealing without any sealant (for at least the 10 minutes or so in my installation test process before I dump in the sealant). They seal up quickly when punctured. They have good grip. The ride quality is good (latex tube-like).
The knocks on them are that they seem to have marginally less tread life and are marginally more fragile than a GP4KIIS. E.g. there are rumors that they are more prone to catastrophic sidewall cuts than some other tires, but I have not seen this personally. The tread life issue I confirm. The Pro One's do wear down to the casing in maybe 2/3 of the time I'd wear down a GP4KSII
