It may be nothing new for some folks here.
I'll just pass along what I experience.
https://www.amazon.com/Topeak-Presta-Valve-Extender/dp/B000FIE5SU/ref=cm_cr_arp_d_product_top?ie=UTF8#customerReviews
I purchased 2 of these valve extenders as my latex tubes came w/ non-removable valve cores and this was the only (locally) available valve extenders what would fit non-removable valve cores.
after perhaps 3 weeks of use, Both of the extenders behaved like rockets when pumping my tires.
The issue being that the extenders are a 2 piece between the actual extender and the portion where one screws in the extender onto the tube.
eg: the extender is 40mm, within the extender, there is a 5mm plastis sleeve which is "glued" into the extender. It is this plastic sleeve which one screws onto the valve.
Problem is - it doesn't last with up to 100psi being pumped thru the extender, ultimately this glue fails and the thing becomes a rocket.
I've since ordered (and waiting) for my silca valve extenders.
Just sharing.
Just sharing.
