I am looking for a non dairy recovery drink for post workouts. I would like it to be about a 3 to 1 ratio or even a 4 to 1 if that is what is out there. The only product I've found is by Tailwind. But they are 3 bucks a stick. Which is pretty pricey. At least for me. Not really interested in making my own because I want something I can mix with water where ever I am immediately after my workout. Thanks in advance.
Re: Recovery Drink/non dairy help. [breezy]
I have the same issue. Buy bulk dextrose and non dairy protein and weigh it out to the ratio you want, shake, and enjoy. I used egg protein but now use beef protein isolate (kinda gross?) by carnivor. Its also cheaper. I made probably 20 pounds a year this way for my team.
Post deleted by windschatten
Re: Recovery Drink/non dairy help. [windschatten]
windschatten wrote:
A good Beer is about perfect.... .
Granted I'm sure you said that in jest, alcohol will actually impair post-exercise protein synthesis.
To the OP. I'm assuming this is due to a "dairy" issue.
Do you know if it is Lactose, Casein or Whey that bothers you?
For consideration; most "protein shakes" have the lactase enzyme added, and my personal allergy is to casein, which means that I'm fine consuming things with only Whey protein (The majority of endurance focused protein supplments (Ultragen etc).
If looking for an alternative to dairy: Soy immediately after exercise as it's very fast absorbing and Egg-white prior to bed as it's slower absorbing. Rice, Oat, Wheat, Hemp and Pea protein just aren't worth it due to amino acid and bio availability profiles.
I typically buy in bulk (BulkSupplements.com) and make my own shakes. Beware that egg can be hard to work with and an immersion blender is best.
I talk a lot - Give it a listen: http://www.fasttalklabs.com/category/fast-talk
I also give Training Advice via http://www.ForeverEndurance.com
The above poster has eschewed traditional employment and is currently undertaking the ill-conceived task of launching his own hardgoods company. Statements are not made on behalf of nor reflective of anything in any manner... unless they're good, then they count.
http://www.AGNCYINNOVATION.com
Re: Recovery Drink/non dairy help. [xtrpickels]
I use this and it seems to work okay. I have problems with Whey Protein. The taste is minimally offensive.
https://www.thorne.com/products/dp/vegalite-chocolate-SP672
It's more work than using powder but I make a big smoothie with water, kale or spinach, a banana, berries, chia seeds, ground, flax seeds, and hemp protein power. Gets me in that 3-4 carb/protein range. Takes me about 3 mins to make and clean up the blender. I make it the night before my workout so after I'm done I just go to the fridge and it's good to go.
bigredrude: Apr 26, 18 9:39
