Rounded out Allen Head
The allen head screw on my water bottle cage between my handlebars is completely rounded out. I am trying to replace it, but I can't get it off. Any suggestions? A way to fix at home.
Re: Rounded out Allen Head [breezy] [ In reply to ]
First, try a Torx wrench slightly bigger than the hole. Hammer (gently) it into the hole and try to remove it that way. Torx wrenches usually have enough bite to get it out.
Next, if you can get to the head (it isn't a bolt sunk in) you can use a dremel cutoff wheel to cut a slot into the head, then use a flathead screwdriver to remove it.
After that, it's drilling it out or using a screw extraction tool.
My Blog - http://leegoocrap.blogspot.com
Re: Rounded out Allen Head [Morelock] [ In reply to ]
Thanks so much. I'll try it tomorrow.
sometimes a bit of carbon paste can help as well.
I talk a lot - Give it a listen: http://www.fasttalklabs.com/category/fast-talk
I also give Training Advice via http://www.ForeverEndurance.com
The above poster has eschewed traditional employment and is currently undertaking the ill-conceived task of launching his own hardgoods company. Statements are not made on behalf of nor reflective of anything in any manner... unless they're good, then they count.
http://www.AGNCYINNOVATION.com
The Dremel method works like a charm.
Re: Rounded out Allen Head [2lazy2tri] [ In reply to ]
Agree, that is the best method, just did that this weekend on an old speedplay screw.
if you can get to the underside of the bolt, you can use pliers to turn it.
and your allen keys might be worn out. get new ones.
Swimming Workout of the Day:
Favourite Swim Sets:
Buy a screw extractor set from Amazon from $10. They work amazingly well and have saved my ass many times. Just be sure to follow the directions because they need to be used in a specific order. Not complicated at all but not intuitive either.
This is what you need (or similar).
http://www.sears.com/...o=7&blockType=G7
Thanks everyone so much. I have another meeting tomorrow and will get home and try out the different ideas. Thanks so much. I'll start with the dremel tool and go from there.
https://www-us.wera.de/...reat-tools/hex-plus/
These will probably take it straight out.
Worked for me last year. I bought a screw extractor kit and decided to use this method instead. Link
QFT, did this a LOT on my old Volkswagen back in the day. All of the methods listed here.
