New XS Giant Trinity and essentially want my elbow pads to be on top of the aerobar. Proprietary extension clamps supposed to go on top of the basebar and then elbow pads are bolted into that extension clamp with puts the elbow pad 2.5 cm above the aerobar. At present I've tilted the elbow pad by using one of the OEM spacers in the front position and nothing in the back position and then run the bolts through that setup into the extension clamp underneath the basebar with the extensions coming out from underneath like in the photo. Not stable enough to ride unless I really torque the bolt running through the entire setup. In the photo you can see how I temporarily put this together (with zip ties) to test the position... Looking for suggestions from others to (1) have my elbow pads tilted up 10 to 20 degrees and (2) have the elbow pads on top of the basebar and (3) any neat tricks that people did with eTap (my blip box has been modded to be underneath the top tube cover)...
Thanks in advance.
Thanks in advance.
