The NSW brake track is every bit as good as a normal aluminum brake track in my opinion. The Jet Black brake track is on another level. The Zipps are pretty easy to put tires on and take tires off whereas my Heds have always been a bit tight.
Re: Any feedback on Bontagter Aeolus 5 tlr? [Thomas Gerlach]
Re: Any feedback on Bontagter Aeolus 5 tlr? [GreenPlease]
GreenPlease wrote:
The NSW brake track is every bit as good as a normal aluminum brake track in my opinion. The Jet Black brake track is on another level. The Zipps are pretty easy to put tires on and take tires off whereas my Heds have always been a bit tight.Thanks for the feedback. Btw, what pads do you run with your NSW?
I run the stock Zipp pads... and am still on the first set. To be honest I probably only have 500-750 miles on these wheels and you can visualize the sort of riding I do. Based on pad wear the pads won't last very long for most people. I don't think this is a problem though: Zipp probably did that intentionally as it is better to have sacrificial pads than a sacrificial brake track. In my opinion the soft compound also helps to modulate braking but, then again, everyone seems to have a different definition of what modulation means with regards to braking.
You're welcome to borrow them for a week to try them out. They definitely aren't in the same league as the Hed Jet Blacks (nothing is) but they are on the same plane as good aluminum rims and damn is it easy to get tires on and off.
