racin_rusty wrote:
So the system has 3 redundant back ups against failure and still broke.So many things IMO could have happened, for example you get slack over time in the haul rope. this is adjusted via counter weight or hydraulic ram at the return station.
If you don't you get roll back and (this is a really bad no-no) you could jumper out roll back, instead of re-splicing the haul rope, adjusting counter weight or adding weight (read more chairs). read jumpering instead of fixing the problem.
Any ways IMO multiple maintenance failures in several independent systems (drive, gear box, power systems, braking systems, back up battery systems, hydraulics, multiply redundant safety systems etc...)
2c,
Maurice
