Billyk24 wrote:
If I remember correctly, this rider stated it helps prevent lumbar pain later in the ride when he had a tendency to not tilt his pelvis anterior.
some of you guys have seen this chart:
it's where you all are, and where the pros are. note the pro men have a much more tightly defined slope. the person who's red square is the longest/lowest is matt. this, as of a couple of years ago. blue diamonds that are even further out there are of other slowtwitchers who've had good success in extremely aero positions, like kiley.
it isn't so much the lowness that gets your low back. it's the length. when your upper arm ceases to be perpendicular to the weight it's supporting (your upper body) the duty to hold up that weight begins to transfer to the low back, the spinal erectors, rather than having the upper body's weight rest, skeletally, on the aerobar pads.
i have no idea if this explains matt hanson's low back. i've never spoken to him about it. (i don't know if he ever did have low back pain; i'm just stipulating to the comments here verbatim.) but just, in general, the solution to low back pain is more often pulling the armrests back. in fact, it's often pulling the armrests back and lowering the rider rather than raising him. or her! do you remember SLOgoing's before and after "not diggin' it" fit videos?
as to the downsloping of the saddle, jim@ERO's right. ISM says its rails should be level and that means the saddle's nose is downsloping. there are two elements to this to pay attention to (don't make it harder than it should be):
1. when you start to slide off the front of the saddle, it's sloping down too much. if you have to tilt the bars up, using the bars to keep you from sliding forward, that's too much. you don't want your pedal stroke to both propel you forward and propel your trunk backward onto the saddle.
2. this is easily determined aboard a fit bike that has an easily adjustable saddle angle tilting adjustment. the Purely Custom fit bike has this. Also any fit bike outfitted with a SwitchIt. it takes, literally, fewer than 5sec for a rider to stop pedaling a fit bike, raise the trunk off the saddle, perform a saddle tilt adjust, start pedaling again. "sweetheart, is that better?" or (if i'm fitting a woman), "ma'am, is that better?" it's a matter of comfort (is your soft tissue happier?); or power (can my pelvis rotate? can my legs clear the flanges?); and are you sliding off the front of the saddle? no? then we're not angled down too much.
some of the pure TTers here have a more obtuse shoulder angle than i think is appropriate for triathletes. i have views on that, and i'm happy to have that discussion, but, if someone complains of low back pain 60 miles into an IM bike ride, that's nothing a pure TTer is likely to face. so, while i'm happy to have that shoulder angle discussion with a pure TTer, that's a different athlete and a different sport.
Dan Empfield
aka Slowman
