scott8888 wrote:
As I noted above the issue isn’t that they aren’t measuring direct force. It’s that they aren’t reporting what they measure.
Stryd knows the mass of the pod and they can accurately measure acceleration accurately so they 100% can measure the direct force exerted on the pod. The problem is that they don’t use that force in what they report. Instead they use some complex equation that gives another value.
So they have a power meter they just choose to not report power. The question is why? Either the power number is meaningless or their acceleration measurents are too noisy to use.
Force applied to the sensors in the pod (deceleration/acceleration) are not the same as those applied to the ground. Your shoe and feet flex through the force applied by your body. This is not measured by a pod attached to your laces. So even if they reported the force measured in the foot pod, it would need to run through an algorithm to spit out power. Just as cycling power meters do.
I'm neither defending nor supporting their readings. Just that you need to remember that the "power" number you want, isn't the same as what Stryd and others deem useful.
