140triguy wrote:
I'll have to break it down and see what I do pushing off the wall. It's one of those things that is totally second nature by now. But, I think the process is something like this:
Submerge, knowing that the water will fill the tube. Push off. Blow with a bit of pressure to be sure the water doesn't food into your mouth. As you reach the surface, blow out hard, and the rest of the water will go out the top and through the purge valve.
The thing that is probably the most difficult is that this differs from snorkeling in that the swim goggles you'll be wearing won't pinch off your nose as diving masks will. If you aren't comfortable keeping water out of your nose and mouth simultaneously, you should try some nose plugs. In fact, do try with nose plugs.
One factor in using the snorkel is whether you exchange air only through the snorkel. That is, you inhale and exhale only through the tube. Physiologically, this increases the length of your trachea, meaning you'll have to work harder to inhale. Also, you won't be able to exhale the volume completely out of the tube, so you'll be recycling a bit of air every time. You can bypass this part by exhaling through your nose, so that all the air in the tube is fresh, though it's still harder to draw in. Some coaches don't want any nose exhalations, but if you are just using the snorkel to steady your head, it doesn't really matter.
Some people restrict the opening of the tube by putting some duct tape over it.
Or, if you're like me, you move to Colorado, and that works the same way.
I suppose I could have done IM Tahoe with a duct tape around an illegal snorkel LOL....I did not feel any need for duct tape on that swim!
