I also agree that the best way to do this in your case would be the computer..
Alternatively, just set the shifters to shift the FD up / down, do your adjustments and then switch the buttons back to shift the RD only.
Also, if you're using R8050 / R9150 or even GRX your front derailleur only has one adjustment bolt. You will have to set up the low limit electronically (using the buttons). The dealer manual suggests you can do this using the TT levers, but I've never tried that muself.
Have a look at the dealer manual pages 137(139) / 142(143) https://si.shimano.com/.../DM-R8050-04-ENG.pdf or https://bettershifting.com/...ne-bolt-derailleurs/
BetterShifting.com - Di2 help and guides| BetterShifting Instagram | Terry's Instagram
