Has anyone had any luck using the edco momoblock cassette? I have an old Zipp 10 speed I want to convert to 11 speed.
Re: 10 speed hub to 11 speed? [pedal-boy]
Plenty of other ways to run your wheel.
Re: 10 speed hub to 11 speed? [lyrrad]
And those are?
pedal-boy wrote:
Has anyone had any luck using the edco momoblock cassette? I have an old Zipp 10 speed I want to convert to 11 speed.Not sure exactly what he did, but my local tri shop mechanic converted two pairs of Zipp 101's and an older pair of Zipp Firecrests from 10spd to 11spd for me, without difficulty. I can ask him on Tuesday. That cassette you list was not used.
Colorado Triathlon Company, CO2UT 2021, Crooked Gravel 2022, Steamboat Gravel 2022
Lasco Concepts.
Quite a few threads on this topic.
Re: 10 speed hub to 11 speed? [Xing triathlete]
I have a friend in a machine shop that has done the exact same thing. Just took out 1.8mm on the back-side of the cassette.
Campagnolo freehub and cassette. Job done.
No machining needed ( maybe a slight redish of the wheel)
I reject your reality and substitute my own!
Adam Savage
Adam Savage
The edco cassettes are a bit problematic.
But, if it helps you, several easy (and some free !) 10 speed to 11 speed "conversion" solutions are listed here:
http://darkspeedworks.com/blog-11speed.htm
Happy riding,
Greg @ dsw
Happy riding,
Greg @ dsw
Re: 10 speed hub to 11 speed? [DarkSpeedWorks]
DarkSpeedWorks wrote:
The edco cassettes are a bit problematic. But, if it helps you, several easy (and some free !) 10 speed to 11 speed "conversion" solutions are listed here:
Happy riding,
Greg @ dsw
Re: 10 speed hub to 11 speed? [jaretj]
just did same last week with an oldish Zipp 10sp disc and new 11sp Ultegra cass - spins perfect
Ditch the carbage - Go keto!
I have had no problems running and Edco mono block 11 speed cassette on my older Zipp wheel. Take your time setting up the high and low limits and the indexing and it will work fine.
Re: 10 speed hub to 11 speed? [slidecontrol]
That is what I did with 2 wheels.. works perfect even in an otherwise Shimano groupset.
While a bit more expensive maybe, Freehub and it’s bearings are wear items so not a bad thing to replace it anyway.
You might have to reconfigure the assembly of the hub by changing the position of some spacers but that is detailed in the free hub installation instructions.
Otherwise, simple swap, no machining, no monkeying: it is an OEM solution :)
T. Guertin / Spocket
Xing triathlete wrote:
Lasco Concepts.Yep his products work flawlessly, i've a growing number of customer who have this cassette, easy install and 100% compatible with new Ultegra and Dura-ace.
http://www.lascoconcept.com/en/11s-cassette/
If you can't fix it with you've an electrical problem dude...
