guy2600 wrote:
- Do/can you swim with a 1 piece under a wetsuit? I'm assuming you do as I'm guessing it would be hard to put on when wet but have no idea.
- From what I understand, if you're moving to a 1 piece, you should be ready to pee in it during the race. Is this a common thing? Makes sense but want to confirm.
- I've heard a 1 piece has less padding than a 2 piece bottom which makes sense if you're going to run in it. How much more uncomfortable have people found this on the bike when making the switch?
- Besides applying chamois creme, taping nipples for the run, are there any other tricks to making a 1 piece work well?
If I don't need to change during the transitions and pee without stopping, that would save me more time than dropping 2k on wheels (I think).
I've never peed in a race.. outside of waiting in the water for the start... otherwise you can pee in anything. Was working a race a couple of years ago where a race leader on the run was in a kit that zipped in the back... he's screaming at a young girl volunteer "unzip me unzip me!!" Apparently no lanyard and unable to unzip... if you do get a kit, you can add a lanyard... my point here is have a plan if nature does call. It's not impossible to get out of the kit enough to hit a porta john if you have to.
I don't do anything other than put the kit on and maybe unzip it when I'm running... I use ITU style unzip in the rear kits for the most part. Kiwami is my go to.
