Re: What torque wrench do you use? [SBR10003] [ In reply to ]
Birzman has a torque wrench that works great, comes with all the bits, and it’s own carry case. Definitely recommend!
Taylor Rogers
Manager and Bike Fit Specialist
Fraser Bicycle and Fitness
34501 Utica Rd
Fraser, MI 48026
Re: What torque wrench do you use? [TRogersFB] [ In reply to ]
For torquing small, carbon parts, I have a small wrench that does 2-10NM. I also have a 5 NM handle wrench for aluminum bars, seatposts, etc.
For heavy duty items like pedals, cranks, BBs, etc., using "feel" works well enough for me.
Re: What torque wrench do you use? [vjohn] [ In reply to ]
Even though this is an old post. I searched the forums instead of repeating the process...
Going with the CDI Torqcontrol for my QR6 seat post - 8nm.
My bike's fate is in your hands. No pressure. ;)
Ryan
http://www.SetThePaceTriathlon.com
http://www.TriathlonTrainingDaddy.com
I got plans - https://www.trainingpeaks.com/...dotcom#trainingplans
Re: What torque wrench do you use? [TriJayhawkRyan] [ In reply to ]
I've had success knocking 5-10% off the recommended torque with integrated seatposts/seatmasts. Just to be safe and not crack anything. Always make sure threads are cleaned then greased before assembly, and use carbon paste on mating surfaces.
Re: What torque wrench do you use? [tttiltheend] [ In reply to ]
I do agree that the 'no torque wrench' people are oversimplifying it in certain situations.
Sure, many/most of the bike parts don't need exact torque and you can 'do it by hand'.
But some parts, particularly carbon stems + carbon handlebar combos, really, really should be carefully installed with a torque wrench. It is simply wayyy too easy to either crunch down on that carbon with permanent damage, or undertorque it and result in a catastrophic slippage of the handlebars when you're putting weight on them in a critical moment.
Can some folks do this reliably by hand? Sure, I'm sure even I could do it right by hand 90% of the time without a torque wrench. But if you expect me to say that a 10% error rate is ok with either equipment breakage or a really dangerous handlebar slippage, I'd say that's an absolute no-go.
I've been surprised at both how little AND how hard I have to turn on torque wrenches to get the expected settings - just goes to show that my subjective feel isn't anywhere as good as I thought.
I will admit that certain parts, particularly my bike seatpost, has needed more torque than recommended, so just because you have a torque wrench+carbon paste doesn't mean everything will be magically fine. You still have to test it out in practice.
I just got the Silca T-Ratchet + Ti-Torque kit.
