Alrighty, you can rest assured I have reached wits end if I turn to an internet forum for medical advice. At this point I am running out of options. I have been trying to figure out a strange medical issue for about 8 months now. Starting last August I began to gag or dry heave under the two distinct circumstances listed below. There is no nausea, pain or other symptoms associated with this.
#1 When exercising hard for more than 15 minutes. This is worst in the pool. I haven't really been able to swim in 6 months. For biking and running I am ok going long and easy and also very hard intervals with good recovery. So it is more race-like efforts which consistently trigger gagging. There is no nausea- just gagging until I stop exercising. Cold temps seem better than warm ones.
#2 I have the same gag reflex when I encounter strong smells- both good and bad. This has gotten better over time and cutting coffee (sadness) has helped. If I happen to encounter strong smells like diesel fumes while riding or running= instant gagging.
So, I've been really proactive about figuring this out since it is driving me nuts. At this point we have ruled out all the most likely suspects (GERD, ulcers, tumors) through the following tests:
-Blood work including celiac panel (fine)
-Endoscopy (ok, no real signs of acid reflux, small hiatal hernia which is common)
-Gastric Emptying Study (alas the radioactive eggs I had to eat gave me no super powers and the results were fine)
-CT Scan of stomach/torso (fine)
-Brain MRI (wanted to rule out potential neural causes, no red flags)
-CT Scan of Throat (clear)
I was on the prescription antacid Pantoprazole (80mg) for 4 months. Nothing.
I am on low-dose Amitriptyline working under the theory that I might have hyper-active nerves in my stomach/esophagus. Not sure this is doing anything.
At this point I don't have a clear way forward. Heading up to Mayo Clinic is under consideration. Hoping to get this figured out so I can race 70.3 World Championships in Sept.
I'm also hoping someone here maybe knows someone who has had similar problems and figured out a solution. Any ideas, ST?
