MOP_Mike wrote:
What tool did you use to contour the trigger guard undercuts and remove the finger grooves?For the undercuts, I used these Dremel sanding bands:
https://www.amazon.com/...01?ie=UTF8&psc=1
The large band is the perfect size the single undercut near the grip. It fits perfectly and cuts the perfect size.
For the second undercut, I used the medium band. I taped off where I wanted the cut and sanded it down from there.
After roughing out the undercuts, I used sandpaper wrapped around a medium Sharpie to smooth it out. Used 400, 800, 1200, and 1600 grit, in that order. Then used Dremel polishing compound with felt polishing bits to get the plastic shiny and OEM looking.
I used the same Dremel sanding bands to remove the texture. Several people used these to remove the finger grooves as well. But, that did not look like a good idea. So, I used a Generic mini 1x30 belt sander, which worked perfectly: https://www.amazon.com/...ge?ie=UTF8&psc=1
Finally, I used the Dremel flexible shaft, which is MUCH easier than holding the Dremel: https://www.amazon.com/...ge?ie=UTF8&psc=1
If there are no dogs in Heaven, then when I die I want to go where they went. - Will Rogers
Emery's Third Coast Triathlon | Tri Wisconsin Triathlon Team | Push Endurance | GLWR
