I want to get a Shimano Flight Deck Computer. Since I ride an indoor trainer a lot, does anyone know if I can use it with the sensor on the rear wheel? And, if so, is this true irregardless whether I use a wireless or wired bracket? Thanks.
I don't know if they make a rear mount sensor or not. You would need to check with your LBS. I cannot find one on the web, but I know they make more sensor units then I can find.
The wireless system will most likely not work. You need a clear path between the sensor and the reciever. You are not likely to get that using it as a rear wheel mount. The front ones sometimes do not work well.
Let me know if you find one, I spin frequently and would like to have the cadence work there as well.
"Remember: a bicycle is an elegant and efficient tool designed for seeking out and defeating people who aren't as good as you."
--BikeSnobNYC
--BikeSnobNYC
