The GMAN wrote:
Feighathlon wrote:
The GMAN wrote:
TriRig wrote:
The GMAN wrote:
TriRig wrote:
The underside of the Alpha One dragonfly is a great spot, which you can see in this article: https://www.tririg.com/...1x_Review&num=36
Another great spot for the new AXS blipbox is just to store it in the Omni storage box behind the stem.
How do you get an M4 bolt that goes into the blip box threaded into the M5 Dragonfly?
The M4 bolt actually passes through the Dragonfly, without engaging the M5 threads in the Dragonfly. Instead, it threads into the M4 threads in the BlipBox. Does that make sense?
Bike is finally together. Looks great!
My front tire rubs pretty hard against the tire shield part of the Delta cover. Any suggestions? I need a few millimeters more of clearance. I really don't want to fart around with all that's involved with cutting it (nor should I need to) since it was supposedly pre-cut to fit the bike.
If you put a washer or two under the Alpha One stem you can effectively raise the Delta cover to give more vertical clearance for your tire if that is the issue. Should be able give you a couple extra millimeters without filing anything.
I'm going to put in one of the standard 5mm round stem spacers under the Alpha One stem. That "should" give me the clearance I need hopefully without mucking up the steerer tube length and making me use a different fork topper. I will also replace the set screws with M4 screws.
Thanks for the comments. Sometimes the most obvious solutions aren't obvious. :-)
Absolutely. We’re just too used to complicated workarounds with other bikes!
Also, since I don’t think it has come up and I know other people may be looking for a solution. If you use a Garmin Varia rear light and are trying to figure out how to mount it with such a deep seatpost, the K Edge splayd Mount (or any other similar mount I guess) works great and is very stable in the boss’s of the seatpost. Just have to find the right screws and it’s really a perfect solution without rubber bands or custom made mounts!
Adam Feigh
Pianko Law, Speed Hound, Castelli, Sailfish, Base
Feighathlon.com
