Does anyone have a CR.901 with the new Enve 7.8s on it? I have the 6.7s and am upgrading, but the new rims are much wider and with Guru non-existent, can't ask the manufacturer! Curious if anyone has this combo, or a set of wheels of similar width (front 29mm, rear 27.5mm).
LazyMarathoner: Jun 10, 16 6:19
Wondering basically the same thing. Contemplating HED Jet Plus at 25mm rim width. Time to find the calipers and measure.
I have a GURU CR.301 very simalar frame\fork.
Currently running 23mm tires, but wouldn’t anticipate any probs installing bigger tires & wider wheels.
If you have the horizontal drop-outs in the rear, you can back off the adjusters.
The brakes might be a problem tho
Let us know if it works
res, non verba
