Hi!
Looks like I'm doing swissman 2016, and I've started thinking about how to pace the bike leg. As most of you probably know, the bike leg is insanely hilly (ref course map below):
With that profile I guess you can forget about an even distribution of power along the course (f.ex - I guess it would be pointless to try and hold 225watts on the climbs AND the decents - probably not even possible due to the steep decents with hairpins etc).
So - I'm guessing that this type of bike leg calls for a different pacing-strategy than your normal flat bike-leg where going out at IF 0.7 - 0.75, and holding this as even as possible, is the best approach. I'm guessing it is sensible to go pretty much at 0,7-0.75 IF for the flat section in the start, but as soon as the real climbing start, I guess it is ok to go for a higher wattage going up, given that you will go at approx 0 watts for the decent? I'm guessing I can forget about trying to achieve a certain AP/NP for the entire bike-leg - more sensible to aim for a certain %% of FTP going up? Should one set a "max" wattage to allow yourself uphill? How high could this max be as a percentage of FTP? As another factor I would add that this type of profile probably gives you abit more room to take in nutrition without pushing to much power? I guess I will be eating alot more on the decents than the ascents ?
any tips here are really welcome! I have ridden a lot of hilly bike-races, but in that case its all about sticking with the pack. Probably not a good idea to go all out until you blow in this case :)
FYI this will be my second IM, have done one flat IM before, and several halfs/ Oly's, if that helps.
