Re: Zipp Vulka Alumina BTA Mount [russomc] [ In reply to ]
Resurrecting this to add more info on this product.
Just called ZIPP to see if there was a way to get this product to work with Wahoo Bolt/Bolt 2--there is not currently a solution. The Garmin plastic mount piece is a press fit & you would not be able to remove it without damaging it. The gal I talked to did send the suggestion to change / modify the product up personally to their Product Manager, as Garmin is losing out to some Wahoo share of the market. That said, it would also seem others would bypass this ZIPP product due to the fact it is not compatible with the Wahoo Bolt or Bolt2 computer at this time.
So...if you want a Wahoo Bolt, you don't use this. If you want a ZIPP BTA, you won't be using Wahoo is what they said.
