Re: The New Felt IA - IA 10, 14, 16 [IamSpartacus] [ In reply to ]
Another thing; if your bike has one of the cables running through the stem, I forget which one they do that with, take it out and just run it into the frame. It's so much easier and works much better.
''Sweeney - you can both crush your AG *and* cruise in dead last!! 😂 '' Murphy's Law
Re: The New Felt IA - IA 10, 14, 16 [Sweeney] [ In reply to ]
my back hurts just looking at your bike fit
Re: The New Felt IA - IA 10, 14, 16 [casper3043] [ In reply to ]
I’m completely comfortable on the bike. Two years ago, I was seeing a chiropractor for neck issues after a car accident. I showed him that pic and he joked “no wonder your neck hurts!”
Awesome thank you!
Hey guys, does any of you know if this site is safe?
http://www.gecycles.com/...search_query=felt+ia
They sell IA bikes and frames for crazy prices, but do wonder if they're second hand.
Ok it says new product, but the price... seems suspect
Re: The New Felt IA - IA 10, 14, 16 [MrBuli] [ In reply to ]
A site in Singapore that claims to have every size of each model in stock, at less than half price.
Looks legit................
Re: The New Felt IA - IA 10, 14, 16 [SBRcanuck] [ In reply to ]
The most expensive bike is probably not even sold for 2.5k... You can get the IA FRD fully mounted for nothing, it's peanuts.
I think these are just faked copies exported from China
Re: The New Felt IA3 Disc Vs IA10 [teinvall] [ In reply to ]
What bars to you have?
Re: The New Felt IA3 Disc Vs IA10 [thagan] [ In reply to ]
I use stock base bar, extension clamps and armrests. Armrest pads are Ceegees and grips are ESI grips made of silicon, they are the thinnest “Racers edge”, and yes they were a pain to get on due to the Di2 wire. The extensions are aluminium Zipp Evo 110. The computer mount / BTA mount is my own design replacing the stock Felt bridge. I added 10mm of width to the bridge to have my thumbs barely touch when holding the extensions.
Ironman 70.3 WC 2019 qualifier
Personal best:
Ironman 9:22:02
Ironman 70.3 4:20:00
It's Devoxx cockpit.
Guys, does anyone know if this is a good wheel?
https://www.amazon.com/...icycle/dp/B071RVG1FF
Seems cheap and light.
Re: The New Felt IA3 Disc Vs IA10 [MrBuli] [ In reply to ]
I have a 2016 IA16, what left side crank power meters are compatible with this frame? For what I can see looking at some models (Stages, Power2Max, Rotor...) the clearance of the crank arm with the rear brake seems to be an issue, do you have any recommendations for crank base power meter for this specific bike?
Thanks.
Re: The New Felt IA3 Disc Vs IA10 [DaniD] [ In reply to ]
I would ditch the stock brake and install a Shimano direct mount brake. That TRP brake is total crap and requires a noodle for cable routing. A cheap Shimano brake is infinitely better and solves any potential brake clearance issues.
Re: The New Felt IA3 Disc Vs IA10 [exxxviii] [ In reply to ]
My IA16 came with Shimano BR-5810 105 direct mount
Aah, that would be sweet update from my 2016 IA16 that came with the TRP turd. In that case, you might be good. Does that brake extend outside of the BB area? (I put an Omega X brake on mine, which has no potential crankset interference.)
Looking for suggestions for crankset updates to current Vision Trimax crank, I believe inside a FSA MegaExo BB (2019 Felt IA10). Any recommendations on cranks that work with IA geometry? I'm willing to install a different BB if needed, just looking for options to move to a 165 mm crank from 172.5. It seems like there aren't many MegaExo options around, or I don't know anything about BB's (the second point is a guarantee). Suggestions and/or tips appreciated!
Re: The New Felt IA3 Disc Vs IA10 [DZ_Matt] [ In reply to ]
Ultegra or dura ace
the world's still turning? >>>>>>> the world's still turning
A pioneer PM will work
A shimano will fit in the mega exo but not the other way around, which means it doesn’t fit neither.
It’s a little little too small. You might have more wear than needed. Found it out by accident when I wanted to put the fsa into the Shimano BB. You just need a proper tool to remove and install.
-shoki
Re: The New Felt IA3 Disc Vs IA10 [shoki] [ In reply to ]
So there wouldn’t be any issues with wear if I put shimano in MegaExo though?
I think you’ll have more wear than you should cause it’s a little more lose although it isn’t lose if you know what I mean.
-shoki
