louisn wrote:
Yeah, at your weight, better have more tire volume IMHO. You sure are more prone to flats than my 110 lbs daughters. I hope you ride at least on on 25 mm's, I'd go up to 27-28 mm tubs combined with large rims, for a nice tubular/rim interface. You won't break a rim, you have more chances to break a rim on a clincher if you flat.
Heavy riders like Tom Boonen and Fabian Cancellara did many Paris Roubaix races on 27-28 mm tubs, Tom Boonen said he put 65-85 PSI (f-r), they weight 180 + lbs (and believe me they smack a lot of cobbles head on at high speeds in that race). Boonen didn't flat more often than others...
Tire width doesn't seem to have any bearing on this problem. I had 28mm Rubinos and they failed. Also a 27mm Vittoria Pave CG failed. My preferred width is 25mm although I do sometimes ride on narrower widths up front. Incidentally, these failures are FAR more frequent in the rear, which is probably obvious at this point.
Quote:
I don't believe in high pressures anymore. So many tests to prove this now.
I don't think it has to do with poor gluing, but rather extreme pressure on the tube seam near the valve. High PSI and a few good "hits" and the tube will fail at the weak point, like said earlier IMO. I could try lower pressures closer to 100PSI but don't want to go any lower than that. If pressures are so problematic, then why do manufacturers print upper limits on their tires at much higher pressures than I inflate? Is that intended for featherweights?
Rocky M wrote:
Currently using Specialized Turbo Mountain Climbing 21 mm (I think) tubulars. Super light & Tom A. here on the forum actually suggested them for super low rolling resistance. I actually agree, they are a fantastic tire would buy them on the sale periods Specialized would have.
Never heard of the tire but great to know. If the reliability and construction is good I might just try one out to see. At this point what do I have to lose? Heck, I think Specialized is the only brand of tubulars I
haven't tried. Always loved the brand when I rode on clinchers but I never see any LBS carry their tubulars as regular stock. It's all Continental and Vittoria here with the rare Tufo and Bontrager.
