dan,
i'm very interested in what you said about a high cadence. riding a high cadence in a triathlon will help you have an easier run transition. so if one was NOT worried about aerodynamics but just having a better run experience...buying a tri geometry bike would not make a significant difference....it's more about the way you ride and developing your body to be able to jump from bike to run without too much physical shock......
¥ as a rookie i'm interested in good fundamental practices...NOT the minutia(sp) of theory, although it is interesting
¥ unless things change i don't see any significant advantage riding a tri geometry bike over a road bike in order to have a better run....i was wondering if a lot of people would say, "you have to get a tri geometry bike because it really alleviates a lot of the struggle when getting off of the bike and running...but i don't see that...it's about training...."
¥ buy a tri bike for aerodynamics not because it helps you on the run UNLESS higher cadence is easier on a tri geometry bike....
¥what about the SLAM position....??????? you get aerodynamics too but on a road bike???
