Hello wannabefaster and All,
View-Speed will 'cheerfully' refund your money ..... if you do not want to keep the Cyclops glasses just return them for a full refund.
While most cyclists adapt to using the Cyclops quickly .... a few cyclists find it perceptually uncomfortable to ride without holding their head up ....
We are happy to have you try the Cyclops glasses and we understand that they may not be comfortable for everyone.
You need to specify your dominant eye when you order and you need to have normal vision (contacts are OK but glasses do not work).
The concept is sort of like flying an aircraft on instruments ..... except that at any time you can lift your head just a bit and see the real world.
I takes a couple of weeks for most folks to feel comfortable riding with the glasses.
When cycling with motorists or when other dangers are present you should have your head up and be alert.
After using the glasses for a while and you become comfortable with them ...... it is important to lift your your head just a bit and look over the prism 'to the real world' occasionally with both eyes ...... and not get entirely in the rhythm of a virtual world detached from the real world world context.
Besides usually making you faster because your head is down (how much faster depends on your current position) the glasses enable you to relax you neck and concentrate on 'turtling' and maintaining a good aero position.
The glasses currently offer a simple appearing design ....... and are the evolution of many different trials and experiments over several years to find the design that works best.
The glasses the prism are mounted on currently ...... are manufactured to View-Speed specifications for fitment and to meet UV blocking ..... and coated to help prevent moisture from adhering to the lens. The glasses are shatter proof (except for the prism) and are while light in weight are about 50% thicker than standard sunglasses. The glasses are slightly tinted.
I will see if I can get permission from some Cyclops users to post their thoughts.
If you have questions please PM me.
Cheers, Neal
+1 mph Faster
Cheers, Neal
+1 mph Faster
