zigor911 wrote:
I am about to go down the same path, and was wondering if/how you were able to fit internal junction box? Also did you end up with the battery in the frame or seat post? THanks in advanceOn the P3 you can not insert the the internal junction box in through the bottom bracket opening. It is just too small. So I ran all my wires up the seat tube where I could plug them into the internal junction box with the seat taken out and then simply dropped the plugged wires and internal junction box back down into the seat tube. Fishing the wires was not too difficult. I used dental floss with a small nut tied to it and also a wire coat hanger to get the pull strings in place.
I went with the internal Dura Ace battery inside the seat post. It is a tight fight so there is no movement.
So I have a fully internally wired Di2 system with both sets of shifters. Used the bike in a Half last month and an Olympic Race last weekend and it performed beautifully both times.
I really like the setup and can never see me going back to manual shifting. Good luck and let me know if you have other questions.
