got question to throw to you guys. anyone here know of a disorder where brain power and physical ability slip at an equal rate?
for the last 2 years i have really been sliding. i am not depresed and show no symptoms of anything wrong.
i shy away from mental disorders because i still have a great desire to achieve and spell correctly, but you guys see the results 5 to 100 times a day.
any ideas?
customerjon @gmail.com is where information happens.
Could you clarify your question?
Do you mean that there is a neurological issue that will both cause physical as well as neuro issues at the same decending rate? If so - yes. I have one.
"Do you mean that there is a neurological issue that will both cause physical as well as neuro issues at the same decending rate?"
yes exactly! what do you know? gimme gimme gimme.
I am not at all a doctor...all I can offer is the suggestion that if you think that you have any neuro issues that are not diagnosed - you need to get an EEG, MRI, CAT and possibly a PET scan of your noggin.
If you have been diagnosed with a neurological infraction, are you on Dilantin, Keppra, Neurotin or any other neuro medications that my cause slowed reaction to stimuli?
Many times if there is a neuro disorder that will alter your physical abilities, the cause will be non-brain matter growth of some sort. Physical alterations will be most noticable with Hypothalimus, Pitutitary and other endocrinologial areas of the brain mass.
