I decided to respectfully disagree with most of the advice in this thread and ignore it. Since when has "ignore form, just do lots of volume and work really hard" been good advice, in any discipline?
So I went to Pursuit Athletic Performance today to get advice on my running form, and in my opinion it was excellent. Mildly depressing because there are no quick-fixes, but I feel it was worth every penny. Of course, the real proof of that will be 6-12 months from now when I see if there have been any significant changes in my run form.
THE EXPERIENCE
It wasn't as much a "gait analysis" but more of a "posture analysis". Their conclusions are not simple changes to running style (which they admit are often useless), but instead are essentially physical therapy / rehabilitation to permanently change my day-to-day posture.
MY PROBLEM
I have problems with my posture that are wreaking havoc on my run.
1) My mid-upper back is arched slightly forward and is not flexible (reinforced by slumping at a computer all day)
2) My lower back is arched too much the other way
3) My hip-flexors (front of hips) are tight (reinforced by sitting all day)
4) My pelvis is tipped forward, rather than in a neutral position.
This is bad when running because you end up using muscles to compensate for your misaligned pelvis. It doesn't take long before these muscles are exhausted and your form starts to go to sh*t. (This is exactly what happens to me). It also means that if you take the "just run a lot" philosophy, it probably won't take long before I get some kind of injury, because many muscles are doing things they weren't designed to.
THE SOLUTION
Ironically, they actually gave me essentially zero "running advice", despite a long list of things I do wrong (ie, heal striking despite thinking I didn't). Their analogy was, "Thinking about your running form at this point would be like painting the shutters on a house that's been eaten to termites and is about to fall over". In fact, they recommended that I stop running for a few weeks, because I might as well let my body "forget" my current form. (SIDE NOTE: Just to set the background, I'm not some kind of hunchback mutant who can't even walk. My issues are only "moderate", and my last olympic tri was sub 2:15. The idea is that all issues should be addressed from the core.)
Instead, I've been given stretching and strengthening exercises that are intended to permanently change my day-to-day posture. If I can manage to make this posture unconscious and second nature, it will automatically and unconsciously translate to my running.
My PT is focusing on three primary areas:
1) Reduce the forward arch in my upper back
2) Reduce the forward tilt in my pelvis, and learn how to maintain a neutral pelvis at all times in my daily life
3) Strengthen my hip muscles that provide lateral support
Some of the stretches exercises are to be done done hourly (yes, every HOUR).
BOTTOM LINE
They claim that if you do the prescribed exercises you can indeed permanently change your posture for the better, and these changes automatically translate to improvements in your running form.
I'd recommend their service not only to those who have injuries, but for anyone who struggles with running, and in particular who struggle to maintain your form over long distances.
BUT LOTS OF FANCY ADVICE DOESN'T PROVE YOU CAN CHANGE
I agree, we'll have to see. But it makes sense to me that if there's any hope of actually changing my run, this would be it. Maybe 6 months from now I'll post before-and-after photos from the run video screen shots.
THE EXPERIENCE
MY PROBLEM
THE SOLUTION
BOTTOM LINE
