RBR:
You need up to 7 hours of training a week total. For the run leg, 2-3 hours would be good. Get a base of steady runs in the 2-4 mile range, 4-5 days a week. Develop your sprint endurance run legs. Either year round or 3-4 months before building into the tri season. During the build weeks, keep the mileage and increase speed blocks. Use either Fartlek or intervals. Whatever you like more. During taper days into race day, add in some 150 Meter pick-ups for raw foot speed. Your swimming should build some arm strength that will allow you to pump your run arms for speed without endurance impairment. Be sure to run some strides up and down hills during build training. These will build your muscles and other soft tissue to minimize stress during runs. Also, trains the bone structure.
Know how to race too. That includes pacing, how to react to competitors, stay relaxed, and more. Minimize the weight on the bike. You don't need much in fluids during the race. It's a sprint. If you train an hour a day, your body will be trained for that experience.
Focus on transitions. If you spend 60 seconds longer between T1 & T2 than others, then realize you are giving up a 20 second/mile advantage to your competitors. That's a lot! Start and end with bike shoes in the pedal. Know how and peel your wetsuit to the waist when running out of the water. Take off your cap and goggles by the time you reach your bike. Put on your helmet, glasses, and run thru transition. You don't need socks. You don't needs a gel, or gloves, or anything else you didn't start the swim with a few minutes earlier. Know your exit and entry points and by all means, know where you bike is located and where to return.
Once you get your base in the swim, bike, and run; then speed focus will be your friend on race day to get you on the podium.
https://www.palmtreesahead.com/ https://www.palmtreesahead.com/tactical-learning
