my LBS told me that syntace levers are not compatible with
profile bars. Is this correct?
Appreciate your help, before I place an order
Your LBS is right, the Syntace Space Control levers are not compatible with the Profile base bars. The Syntace levers need internal cable routing. Use the Syntace Stratos bar.
Thanks, so if I want to keep my profile bars I will have to go with the new Profile levers?
If you are talking about the Carbon X integrated bars, you are fine. I have this setup myself. If, however, you are talking about separate base bars and aero bars, then correct, you will have to replace the base bar if you want to use the Space Controls
