310xt Users: Multiple Power Meters Detected?
Anyone out there using their 310XT as a head unit for their ANT+ Power Meter encounter issues when in close proximity to other ANT+ head units? I've gone to Garmin about this and haven't gotten a response, so I figured I'd see if anyone else out there is in the same boat.
Basically, I'm doing indoor group trainer sessions with a few other guys with PMs, I have a Quarq and the guy closest to me has a PowerTap. I haven't had much issue with my 310XT and CinQo in the past, just turn it on, start pedaling and 310 detects and starts reading data. In our basement rides, I'm picking up the power of whoever starts pedaling first, which usually results in me having to have them stop their warm up, then try and get it to pick up mine instead. Even so, once they resume pedaling the 310 will then to proceed to nag with incessant "Multiple Power Meters Detected" messages that I find horribly annoying since they announce a problem but propose no solution, I'm not aware of any way to select or pair with only with a specific meter.
Anyone encounter this indoors or out? I suppose this is a good impetus to not suck wheel during training rides because if I'm picking up everyone else’s readings from just being in the same room it's going to be a nightmare when my head unit is in line 2 feet behind a rear PT hub'd wheel.
Re: 310xt Users: Multiple Power Meters Detected? [tgarson] [ In reply to ]
Going back a long way, but did you ever find a fix for this?
Have been using a Favero Assioma Duo and my Wahoo elerment for a year now.
Just got a new bike with a built in crank power meter. I want to compare the power date they give.
So though I could use the old 310xt to record one PM while the Wahoo records the other.
But gettting the same problem, with Multiple Power Meters Detected 😥
Full-time Engineer / Part-time Pro Triathlete
Instagram - https://www.instagram.com/benwgoodfellow/
Strava - https://www.strava.com/athletes/3085032
Website - https://benwgoodfellow.wixsite.com/bengoodfellow
It's been a while for the 310XT, but if I remember right, this was a quirky bug whereby the 310XT basically went into Tinder-mode, asking everyone for dates.
I thought it was eventually fixed in a firmware update, but I know others fixed it by just hard-resetting their unit.
My tiny little slice of the internets: dcrainmaker.com
