Tubular tire pressure
I have recently made the jump to tubular tires. The tires I choose are Vredstein Fortezza Pro which recommend minimum 185psi max 200psi. The pump I use can not get to this kind of pressure, at around 150psi the pump head just pops off the valve.
Which pumps are the best for high pressures?
Re: Tubular tire pressure [74] [ In reply to ]
I run 140 psi in my tufos, not sure if you need more than that really
