gary sr wrote:
On a 500 or longer swim, breathing twice consecutively or even three times consecutively into and out of turns is a great idea. Shouldn't slow you down much or at all. As for dolphin kicks off the wall, depends on dolphin kick speed vs freestyle speed. test yourself with all out 25 of each. if less than 1 second difference, stay down as long as you can (in a 500 that is still usually 2 kicks and up). If between 1 and 2 seconds 3 or 4 dolphin kicks to breakout (in 200 or less). If over 2 seconds 2 kicks and up for any distance....unless you are over 4 seconds slower. Then don't do dolphin kicks. just use flutter kicks off the wall. BTW, start your first up kick immediately off the wall...no gliding. It is faster. Gary Sr.
OK I thought I should be gliding off the wall for a bit before starting my dolphin kick but you're saying push off and immediately up kick? Sounds like a plan. By the way "riding on the bubbles" was awesome today. I finished my 25x400IM set 3 minutes faster than my target (lane swim was 3:30 cut off time and I knew it was going to be tight and I got done in 3:27). In this set, I was doing zero dolphin kicks off the walls for free. I just glided to around 7m point and rested as much as I could. I will try two dolphin kicks with an immediate up kick the next time I swim the 1500m free.
