In your tri-bike fit article you wrote, "the imprecision of where the crotch actually is." I'm curious as to what you mean. Are you referring to the fact that some people ride "straight up the middle" and some ride with their stuff off to one side or the other, and the fact that the measurements of these places can be quite a bit different? Just curious.
Also, I definitely agree with you that steep saddle height should be slightly higher than slack saddle height. There is .5 cm difference in saddle height between my tri and road bikes. I used to ride them the same, but using "method 3" I have found that I like my tri saddle slightly higher.
